Self-contained Temperature Control Panel from Omega Engineering
By Design World Staff | February 6, 2012
Omega introduces its new series CNI-CB120SB, a self-contained temperature control panel that provides a complete control system design, eliminating the need to select, collect and assemble separate components. The preconfigured panels are ready to install, requiring only supply power, load and sensor hook-up. They are equipped with an OMEGA® iSeries microprocessor-based controller with on/off, PID and ramp/soak capabilities along with a tri-color display. These control panels are supplied with a thermocouple input jack and M12 female connection for RTD or process inputs. Their compact packaging makes them portable or easy to mount, even in limited spaces. Ideal for chemical and food industries where temperature and process control is necessary.
Omega-CNI-CB120SB-temperature-control-panel
Omega Engineering
www.omega.com
Filed Under: Test + measurement • test equipment
mti
MTI
moog
