All that strength training done at the health may do more than benefit the person pumping iron or working the Nautilus machines. The process that strengthens human skeletal muscles is the basis for Hokkaido University researchers to develop a strategy to fabricate materials that become stronger in response to mechanical stress.
The scientists’ findings, published in the journal Science, could pave the way for long-lasting materials that can adapt and strengthen based on surrounding conditions.
During strength training, the fibers in human skeletal muscles first break down, encouraging the formation of new, stronger fibers. For this to happen, the muscles must be supplied with amino acids, the building blocks of proteins, which join together and form muscle fibres.
The Hokkaido University researchers, led by polymer scientist Ping Gong, developed a method to employ ‘double-network hydrogels’ that emulates the building process of skeletal muscles (see video).
Double-network hydrogels are a soft, yet tough material formed of about 85 weight percent water and two types of polymer networks: one rigid and brittle, and the other soft and stretchable.
The team placed a double-network hydrogel inside a solution containing molecules, called monomers, which can be joined to form larger compounds called polymers. This solution emulates the role of circulating blood carrying amino acids to skeletal muscles.
Applying tensile force (stretching) to the hydrogel causes some of its rigid and brittle polymer chains to break. This leads to the generation of a chemical species called ‘mechanoradicals’ at the ends of the broken polymer chains. These mechanoradicals can trigger the joining up of the monomer absorbed into the hydrogel from the surrounding solution into a polymer network, strengthening the material.
With successive stretching, more breaking down and building up occurs, similar to what happens with skeletal muscles undergoing strength training. Through this process, the hydrogel’s strength and stiffness improved 1.5 and 23 times respectively, and the weight of the polymers increased by 86%. The team was further able to tailor the material’s response to mechanical force by using a specific monomer that altered the gel’s reaction to heat; heated at high temperatures, the gel’s surface became more water-resistant.
The researchers say their work could help with the development of self-growing gel materials for applications as flexible exosuits for patients with skeletal injuries; these suits would potentially become stronger and more functional the more they are used. Professor Gong explained “Since many types of DN gels have similar mechanical features, this process could be applied to a wide range of gels, expanding the range of potential applications.”
Filed Under: Product design
