    • On the Floor
Sendix F5858 industrial ethernet encoders with PROFINET IO interface
By Mike Santora | December 14, 2021
z4636-F5858-Profinet-enc-std-srgb-webNew generation Industrial Ethernet encoders with PROFINET IO interface.
The optical absolute Sendix F58 PROFINET IO encoder is ideal for real-time applications. Thanks to the new technical platform, the encoder can also be integrated in PROFIdrive networks. The vertical communication, from control level to industrial production facilities, enables location-independent parameterization, remote diagnosis as well as priority-assisted process data exchange. Even maintenance work can be done in less time.
Latest PROFINET functionality
PROFINET IO, RT, IRT
Supports isochronous mode
Latest encoder profile (V 4.2)
Supports isochronous cycle times of a send cycle up to 250 μs and a jitter < 1 μs
PROFIdrive profile
Reliable and robust
Integration in applications with different performance requirements
Can be implemented in networks for tough real-time requirements with cycle times < 1 ms
Complete support for all Profinet features
Suitable for highly synchronous applications such as axis synchronization
Interoperability between diverse control and drive manufacturers thanks to PROFIdrive
Kubler
www.kuebler.com
Filed Under: Encoders • absolute
Tagged With: kubler
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
