Sensirion is known for its innovative products, customized solutions and excellent support. Our products set the standard in markets around the world. At this year’s edition of Sensor+Test 2014, we will exhibit new and refined sensor solutions for measuring gas and liquid flow, differential pressure, humidity and temperature. Among other things, you can learn more about the products illustrated here:
Environmental sensing for a smarter life
Sensirion opens up new possibilities for the wearable and mobile market with its unique chip-scale packaging technology for the humidity and temperature sensor SHTW1. With miniature dimensions of just 1.3 x 0.7 x 0.5 mm and low energy consumption the SHTW1 will create the foundation for an endless array of applications.
Various versions of differential pressure sensors
Millions of our differential pressure and flow sensors are in operation in the field. Their industry-leading long-term stability is well proven in hundreds of different applications. The sensors come with fully calibrated digital or analog output and have the highest sensitivity and accuracy. The most recent versions feature low power consumption, extended measurement ranges, failsafe certification, and calibration for measuring mass flow in a bypass configuration.
Incredibly small liquid flow sensor
The LPG series offers the most compact liquid flow sensors available today, enabling outstanding performance and speed in the smallest of spaces. The innovative design features our highly sensitive microchip, which measures the flow in a planar microfluidic substrate from the outside of the flow channel. Fluidic ports on the bottom allow easy integration into manifold systems.
Sensirion
www.sensirion.com
Filed Under: Sensor Tips
