Inuitive, a Vision-on-Chip processor company, announced today the launch of its latest sensor modules: the M4.5S and the M4.3WN. Designed to easily integrate into robots and drone systems, both sensor modules are built around the NU4000 Vision-on-Chip (VoC) processor and integrate depth sensing and image processing with AI and VSLAM capabilities in order to provide robotic devices with human-like visual understanding.
The M4.5S provides robots with enhanced depth from stereo sensing along with AI-based obstacle detection and object recognition. It features the widest field of view in the industry at 88×58 degrees, the shortest minimum sensing range of 9 cm, and a wide dynamic operating temperature range of up to 50 degrees Celsius. The M4.5S is an easy-to-adopt, highly power-efficient platform that is designed to function as a self-sufficient depth sensor module and shorten time to market for commercial robotic systems with industrial design fix and limitations.
The Company’s other newly launched sensor module, the M4.3WN, features accurate tracking and VSLAM navigation based on fisheye cameras and an IMU, together with depth sensing and on-chip AI processing. This enables free navigation, localization, path planning, and static and dynamic obstacle avoidance – the main challenges for AMR and AGV systems. The M4.3WN is specially designed in a metal case to best serve in industrial environmental conditions.
The M4.5S and the M4.3WN sensor modules’ primary processing unit is the Inuitive all-in-one NU4000 processor. Both modules are equipped with depth and RGB sensors that are controlled and timed by the NU4000. Data generated by the sensors and processed in real-time at a high frame rate by the NU4000, is then used to generate depth information for the host device.
The Inuitive M4.5S and M4.3WN module sensors are available today. For more information and ordering, visit: M4.5S and M4.3WN
Filed Under: Sensor Tips
