Sensor Monitoring Unit – SMU and New Version of TPM
By Frank Tobe | September 23, 2014
Schroeder Industries, recognized in filtration and fluid conditioning products, introduces a new version of our TestMate® Particle Counter, TPM and the new Sensor Monitoring Unit, SMU.
The new SMU allows live display of the TCM ISO code, TWS water concentration and fluid temperature. Besides displaying the key contamination data the SMU will also store the data for later retrieval. The following combinations of fluid sensors can be connected directly.
  • Particle Contamination Sensor TCM and Water Sensor TWS-C
  • Metallic Contamination Sensor TMS and water Sensor TWS-C
Our TestMate® Particle Counter, TPM is now available with two new options. You may now order the unit without the internal pump, which can be installed in systems with operating pressures up to 5000 psi. The pump-less version can also be ordered with Viton® seals allowing the unit to be used with Phosphate Ester Fluids.
www.schroederindustries.com
Mobile Hydraulic Tips
Tagged With: schroeder, schroederindustries
Mini machines draw ICUEE crowds
excavator1
Why do cylinders fail on an excavator?
AgfaPhoto
What makes a quality hydraulic component?
A look ahead with JARP Industries’ CEO, Kevin Kraft
