Sensoray highlights Model 3011 miniature 13 Megapixel HD IP camera with H.264 compression
By Megan Hollis | September 22, 2014
Sensoray announces its Model 3011 miniature HD IP camera, ideal for security, surveillance and monitoring. Featuring a robust 2.25 x 2.00 x 1.20 inch enclosure, including the lens, the Model 3011 can produce an H.264 or JPEG compressed stream at resolutions up to 1080 lines at 30 frames per second (fps), and two simultaneous streams at lower resolutions. The camera produces 13 megapixel JPEG snapshots at 5 fps and supports resolutions up to 4192 x 3104.
Picture of Model 3011
The Model 3011 is equipped with a variety of advanced features, including autofocus, auto white balance, image stabilization, and ultra-tough packaging. It consumes less than 3 Watts of power using power over Ethernet (POE) or an external 5 V power supply. A high-sensitivity complementary metal– oxide–semiconductor (CMOS) image sensor combined with an advanced image processor delivers excellent video and still image quality.
The camera performs efficient H.264 video compression ([email protected]) and outputs the compressed video in MP4, transport stream, or AVI formats. Two separate output streams — each with independently configurable resolution and bitrate — can be generated for some combinations of resolutions.
Built-in overlay generators allow up to 160 text characters to be positioned anywhere in the video frame. A unique text string, consisting of mixed constant and variable text, may be defined for each overlay generator. Such text variables as time, date, and frame count are automatically updated every video frame.
The Model 3011 has a powerful and configurable web interface, with a built-in web server that facilitates device configuration and control, user management, and live stream previewing using any web browser. Each output stream can be directed to a specific network address for remote recording or display with a player application such as VLC media player.
Sensoray
www.sensoray.com
Filed Under: Vision • machine vision • cameras + lenses • frame grabbers • optical filters
Tagged With: Sensoray
Beckhoff increases visualization capabilities with machine vision-specific control software
Cameras ensure vaccine vials meet high quality standards
innovations in optics
Drivers handle LED modules for spot curing, sculptured vision, industrial apps
QN-HD Size Comparison w Old Model
InterTest’s 7mm QN Camera lives on in high definition
