    • Subscribe!
Sensoray Introduces PCI Express Analog and Digital I/O
By Natasha Townsend | February 7, 2013
Sensoray announces the newest member of their extensive line of OEM data acquisition cards with the release of the Model 826, a PCI Express Analog and Digital I/O board with multistage watchdog timer.
Featuring
6 encoder/timer/counter interfaces, 16 differential analog inputs (16-bit, 300 kS/s), 8 analog outputs (16-bit, 900 kS/s), 48 bi-directional digital I/Os with edge capture, 3-stage watchdog timer and output fail-safe controller.
Its six 32-bit counters can operate as conventional timer/counters or in any of several special modes, directly supporting incremental quadrature encoders, PWM and pulse generation, frequency measurement, period measurement and pulse width measurement.
The board’s watchdog timer and fail-safe controller work together to automatically assert fail-safe output levels in response to faults or external triggers. This makes the Model 826 well-suited for a wide range of measurement and control applications, including those requiring fail-safe operation and automated error recovery such as beverage and food processing, amusement park rides and laser cutting systems.
Sensoray
www.sensoray.com
Test & Measurement Tips
Tagged With: sensorary
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
    • Subscribe!
