Sensors deliver better than 1 µm of accuracy for X-Ray telescope assembly
By Editor | November 2, 2012
NASA’s newest orbital X-ray telescope technology uses capacitive displacement sensors during the assembly procedure. The sensors, capable of resolving position to less than 10 nanometers, are used during the mounting of over 10,000 thin glass mirrors into the telescope’s “lens.” Each mirror is about the size of a sheet of paper and only four times thicker – they are very delicate. Achieving the required optical specifications for the telescope requires that each of the mirrors be mounted into position with better than 1 µm of accuracy. The mirrors must be able to hold this positional and angular accuracy during launch and deployment in space.
A specially designed machine holds the mirrors precisely in place while they are bonded to mounting tabs with ultraviolet cured epoxy. The Elite Series capacitive sensors monitor changes in the mirror position during the epoxy injection. The machine adjusts the epoxy pressure to precisely move the mirrors into the proper position.
web-image_opt
Previously, laser displacement sensors were used but were eventually abandoned because of insufficient resolution, size-related mounting difficulty, and generation of too much heat causing thermal expansion of the components during the delicate operation. The capacitive sensors are less expensive, small enough to easily mount, and generate virtually no heat during operation.
Lion Precision
www.lionprecision.com
Filed Under: Aerospace + defense, Design World articles, Sensors (position + other)
Tagged With: lionprecision
