Sensors with Flexible Mountings
By Design World Staff | May 8, 2009
The Z and ELF Photoelectric Sensors will reduce material and labor through mounting flexibility and easy setup.  A standard front mount or a spherical ball mount, when combined with a swivel bracket, makes these sensors adjustable. They are all rated IP 67 for harsh environments. The sensors can be tailored to specific needs: cable cut to length, addition of different connectors, brackets, customer-specific cable label, bulk pack, kit with reflector/bracket.
The ELF3 Photoelectric Sensor has three variations, retro-reflective, fixed background suppression, and energetic, . The ELF4 Sensor includes a 24 mm spherical front mount for adjustability. The Z1/Z2 Right Angle Cable has three variants: retro-reflective, fixed background suppression, energetic; and a clear housing for 360‚° status indication.
SICK
www.sickusa.com
Filed Under: SENSORS, TEST & MEASUREMENT
