Serial Interface MAC-PWM Card
By Patrick Curran | February 19, 2009
Gasport, NY – Entertron Industries Inc. introduces the MAC-PWM card.
The Multiple Application Control board has been designed with flexible I/O whereby different applications can be designed around the board. The first application is a two channel high current PWM output card that can be interface either through analog outputs from the PLC or via RS485. Protocols available will be ASCII and ModBus RTU. With the incorporation of the RS485 port, multiple units can be interfaced to a single PLC.
The MAC – PWM card can be ordered with either one or two high current PWM outputs. The units are capable of up to 5 amps / PWM output. An enhanced version will also be available, with the capability of up to 15 amps / PWM output.
The MAC design also includes the following:
• Power – 8 – 24 VDC
• 1 optically isolated input capable of up to 32 KHz (can be configured as AC input)
• I2C capabilities (replacing the RS485)
• 4 inputs configurable as analog or non-isolated DC inputs
• 2 outputs configurable as either Triac or Transistor.
The MAC design utilizes the PIC 16F88 micro-controller and can be programmed using the PIC Basic Pro software. Other programming platforms available are, PIC Basic, Assembly and C / C++ software compilers, thus providing multiple methods to configure this flexible design enabling it for many different small applications.
www.entertron.com
Filed Under: Computer boards, ELECTRONICS • ELECTRICAL
