Service Robotics Aids Rehabilitation
By Design World Staff | June 14, 2012
Despite a high level of automation, there are still many assembly tasks in industry that can only be performed by humans. Many of these are repetitive tasks that cause fatigue and can be particularly challenging for older members of the workforce. The ExoHand was developed as an effective solution for industrial automation, but it also works as a pioneer innovation in the area of service robotics, such as rehabilitation. In stroke therapy, for example, this hand orthosis can be used to help treat the first signs of paralysis in patients.
The ExoHand is an exoskeleton individually adapted to the human hand. A 3D scan is made of the user’s hand, and then manufactured from polyamide in a selective laser sintering (SLS) process.
ExoHand
Because all joints and their actuators exist in the form of an exoskeleton outside of the actual hand, the ExoHand can be worn over a human hand or an artificial hand made from silicone. There are eight pneumatic actuators that move the mechanical fingers. The fingers can be actively moved and their strength amplified. The hand movements can be registered and transmitted to robotic hands in real time. The exoskeleton structure supports the human hand externally and simulates the physiological degrees of freedom of the hand.
Eight pneumatic actuators move the exoskeleton. Sensors record the forces, angles and distances. Servo pneumatic open- and closed loop control algorithms allow precise movement of the individual finger joints. The ExoHand thus supports the various possibilities for gripping and touching, which a human hand has. The pneumatic components allow highly flexible and ergonomic control of the individual finger joints. High forces can thus be transmitted precisely in a small space and with a low weight without the system becoming rigid and restrictive.
ExoHand
The ExoHand can be used together with a brain-computer interface to create a closed feedback loop. It can help stroke patients who are showing the first signs of paralysis to restore the missing connection between brain and hand. An electroencephalography signal (EEG) from the brain indicates the patient’s desire to open or close the hand. The active hand orthosis then performs the movement. The result is a training effect, which over time helps patients to move their hand again without any technical assistance. Festo is working together with the Centre for Integrative Neuroscience at the University Hospital Tübingen on this subject.
Festo Corp.
www.festo.com/us
Filed Under: The Robot Report, Medical-device manufacture, MECHANICAL POWER TRANSMISSION, Motion control • motor controls
Tagged With: festo
