The Servometer®/ PMG, LLC line of gold plated bellows are especially suited for dynamic interconnect applications; absorbing shock and vibrations, while maintaining continuous connection.
Servometer contact springs are manufactured from electrodeposited nickel alloy and gold plated to ASTM B488-01, to enhance their conductivity. Most of the end cups are designed to fit over standard sized pins or into recesses, connecting them to other components without the necessity of soldering. They provide extremely low DC resistance with a minimum of insertion loss, and are designed to provide lifetime spring and force repeatability. They are ideal for applications where contact with a delicate component or material is required.
With diameters ranging from .037 inch O.D. (1 mm) to .245 inch O.D. (6.22 mm), these precision contacts are available from stock. Custom contacts can be designed with bellows diameters as small as .020 inch (.5 mm).
Servometer contacts are rated for a maximum current of 4 amps, and can be safely used up to 260° F and maintain their full spring qualities.
Servometer® / PMG, LLC
www.servometer.com
Filed Under: Fastening + joining, Shocks + vibration control • gas springs
