Larson Electronics has announced the release of a seven watt chemical resistant industrial LED beacon equipped with a 100-pound grip magnet.
The GAUSB-CRNM-LED-PC-M industrial grade LED beacon light from Larson Electronics is a magnetically mounted lighting solution for general work areas where permanent solutions are not feasible. This optional steady-burn or strobe beacon is constructed of corrosion and chemical resistant polycarbonate, USCG accepted, and NEMA 4X complaint for hose-down areas. The seven-watt LED lamp is protected by a polycarbonate lens, adding to the corrosion resistant features offered by the fixture. Light output colors offered by this fixture includes red, amber, blue, green, and white. The GAUSB-CRNM-LED-PC-M is equipped with a 100-pound grip magnetic base for mounting. This is appropriate in locations where the LED beacon is offered in a high voltage configuration, as well as a low voltage configuration and is terminated in a one-foot pigtail with flying leads for connection to the appropriate power source.
“This new magnet mount industrial beacon is ideal for use as a status indicator light on metal machinery where permanent mounting is impractical,” said Rob Bresnahan, CEO of Larson Electronics. “It may also be used in manufacturing facilities and process plants to indicate that an operator may need some assistance in the field.”
Larson Electronics
www.larsonelectronics.com
Filed Under: TECHNOLOGIES + PRODUCTS, Lights • signal lamps • indicators
