  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
SF type gear spindles for mine rope shovel applications
By Mike Santora | January 9, 2019
Ameridrives-shovel-Open-Pit-Mine-application-imageA global mine rope shovel manufacturer required a robust replacement coupling solution that could accommodate a high degree of misalignment due to the deflection that occurs as the massive machines twist and flex during loading, unloading and rotating.
The large electric shovels, weighing over 860 tons, with payload capacities over 120 tons, remove overburden and minerals including coal, and load it into haul trucks at large open pit strip mines around the world. The couplings are installed on drive motors that operate the shovel’s propulsion, crowd, swing, and dipper/bucket hoist winches.
AC-Amerigear-SF-SpindleThe OEM consulted with Ameridrives engineers to help solve the deflection/misalignment problem associated with the gear couplings originally installed on its shovels. After a careful review of the application challenge, Amerigear SF Type flexible spindles were selected. For many years, Ameridrives had been manufacturing gear spindles designed to accommodate high torque and high misalignment for the steel industry, so the gear spindles were a natural solution.
Ameridrive SF (Flange Type) spindles feature special molded high angle lip type seals, custom gear tooth geometry, and gear teeth that are heat treated to provide higher torque ratings. The AISI-1045 induction hardened spindles provide up to 6° of misalignment. The 13.62-in. and 16.56-in. diameter couplings are the most common sizes used with a torque capacity of 1,621,400 in.lbs.
Ameridrive gear spindles continue to provide exceptionally reliable performance for decades in rope shovels worldwide.
Ameridrives
www.ameridrives.com
Tell Us What You Think! Cancel reply
MOTION DESIGN GUIDES
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
  • Create your perfect machine with Advanced Engineering
  • How a ME/EE turned passion for design into his own bike company
  • Everyone Can Save on Cable Costs. Here’s How
  • How and Why You Should Use a Wave Spring for Bearing Preload
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
