Shaft couplings for torque transducers
By Mike Santora | October 13, 2016
Coupling Tips
mayr-corp-roba-ds-imageDesign
ROBA-DS disk pack couplings of the type series 9110 and 9210 from Mayr are especially adapted for the attachment of HBM torque transducers. Different types of construction and flexible combination possibilities permit the integration of measurement flanges in almost every test stand and drive constellation.
Function
ROBA-DS disk pack couplings compensate for axial, radial and angular shaft misalignments. Torque measurement flanges are precision transducers, using which the measurement of extremely small measurement uncertainties can be realized. However, for this purpose several prerequisites are necessary. One of the most important is the minimization of the parasitic loads affecting the transducer, which amongst other things are caused by alignment errors in the drive line. The use of the ROBA-DS as a torsionally rigid and backlash- free compensating coupling provides the prerequisites needed for exact measurement results of the torque transducer.
Characteristics and Advantages
• High precision and reliability
• Optimum running smoothness
• High speeds
• Robust and highly dynamic
• Different designs for optimum set-up
Mayr Corp.
www.mayr.com
Filed Under: Coupling Tips
Tagged With: mayrcorp
Friction bearing universal joints for packaging applications
Sensata Technologies adds Predictive maintenance for rotary equipment
KTR RUFLEX torque limiter with BoWex gear coupling
Ringfeder on Carlyle Johnson JEB electric jaw clutches
