A new standard line of machinable shaft-end adapters that are offered with a plain bore or keyway and a variety of options is being introduced by Stafford Manufacturing Corp. of Wilmington, Massachusetts.
Stafford Machinable Shaft-End Adapters feature the Accu-Clamp™ design with an integral clamp on one side while leaving the other side fully custom-izable by the user. Available with or without a flange, these parts can be modified by the user or by Stafford and are offered with a plain bore or keyway for greater torsional holding power and fixed shaft phasing.
Ideally suited for use in conveyor systems and special machinery, Stafford Machinable Shaft-End Adapters can be provided with options including custom bolt-hole patterns, indexers, cam profiles, milled slots, and more. Available in aluminum, steel, and stainless steel, they come in 11 standard bore sizes from 0.5” to 2.0” I.D.
Stafford Machinable Shaft-End Adapters are priced according to style, material, size, and quantity. Pricing is available upon request.
Stafford
www.staffordmfg.com
Filed Under: Coupling Tips
