Sherborne Sensors Debuts U2000 Series Miniature Load Cells
By Patrick Curran | February 19, 2010
Sherborne Sensors has announced the global market introduction of the U2000 series, a new range of compact miniature universal load cells, designed for precision tension and compression force measurements in space constrained environments.
sherborne-U2000-load-cell
Offered in ranges from 1 to 50kN, the miniature U2000 series load cells provide precision measurement capabilities in either tension or compression mode, with a 3mV/V full scale output. Their robust, shear web design incorporates multiple strain gages, strategically placed to counteract and minimize errors associated with unwanted side or axial forces. A corrosion-resistant stainless steel housing and environmental sealing to IP54 helps ensure reliable performance in harsh environments, over a wide temperature range of -20 to +80°C. The low deflection and high frequency response characteristics of the Sherborne Sensors U2000 series are especially beneficial for both materials testing and high-speed load measurement applications, and particularly, where peak loads are being monitored. Additional available options for the U2000 series range include spherical load buttons, mounting bases, fully isolated double bridge and fatigue rated versions. In addition, Sherborne Sensors custom designs and manufactures variations to conform to specific customer requirements.
Sherborne Sensors
www.sherbornesensors.com
Filed Under: SENSORS, TEST & MEASUREMENT
