Sherex to Launch RIVFLOAT®
By Design World Staff | September 8, 2008
Tonawanda, NY – Sherex Fastening Solutions has introduced the next generation of fastening technology; a patent pending rivet nut with internally floating threads called RIVFLOAT®.
Cross Section of ROVFLOAT® installed.
The internally floating threads on RIVFLOAT® allow for component attachments in off center applications and can accommodate for tolerance stack up in the manufacturing process. The floating nut (.020″ radial float) aligns to drive the angle of the screw and thus eliminates cross threading and spin out. RIVFLOAT® was designed for post installation in applications where cage nuts, clinch nuts, floating nut plates or weld nuts are typically used.
www.sherex.com
Filed Under: Fastening + joining • locks • latches • pins, Screws • nuts • bolts
Tagged With: Sherex
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
