NEW BERLIN, WI — J.W. Winco, Inc. now offers series GN 350.1 Short Model Leveling Sets.
These RoHS-compliant, metric sized leveling sets are made of zinc plated, blue passivated steel, and consist of a threaded upper sleeve and a tapped lower sleeve. They are used for leveling, adjusting, and linking operations of smaller dimensioned components. The fine thread allows precise, stepless setting and locking using a DIN 1810A hook wrench (available separately). An anti-rotation disk serves also as a height limiter for the maximum height. Normally this screw is permanently and securely locked by the static load created when the mounting screw is tightened. If this is not sufficient, the use of a locknut is recommended.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins
