L-com, Inc., North Andover, Mass., has added 1 ft cable length options to its CHD Deluxe High Density D-Sub cables and CRMN Deluxe Panel Mount D-Sub cable lines. This will give customers the option of a more streamlined fit to achieve D-Sub connections in tight or confined space applications, at a reduced cost.
These HD cable assemblies are fully shielded throughout the entire cable to prevent data corrupting EMI/RFI. Metal thumbscrews ensure fast and easy connections and custom lengths and pinouts are available with modest minimum requirements. One foot options have been added to the following product families: CHD15MF, CHD15MM, CHD26MF, CHD26MM, CHD44MF, CHD44MM, CHD62MF, CHD62MM, CHD78MF and CHD78MM.
L-com’s CRMN D-Sub cable assemblies were the industry’s first to feature connectors with threaded inserts. These allow either metal thumbscrews or female hex standoffs to be threaded securely to each connector. They are also fully shielded with molded backshells and 26 AWG conductors. One foot cable lengths have been added to the DB9, DB15, DB25, and DB37 sizes in male to male, male to female and female to female configurations.
“Adding shorter options has proven to be successful with our standard D-Sub cables as well as with other interfaces, so we wanted to make them available to those customers who require the CHD and CRMN products as well,” said Steve Smith, Product Manager.
L-com
http://www.L-com.com/
The post Shorter cable lengths for L-Com’s D-Sub cable lines appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
