All fiber optic cables feature a glass core on which light travels. These glass strands are then protected by a plastic coating, the cable construction itself and its jacketing material. Fiber optic cables used in data centers are available in two types—multimode and single-mode fiber optic cable.
According to CABLExpress, single-mode fiber is fiber optic cable that has a core diameter of 9 µm and offers a higher bandwidth than multimode. This makes them more expensive than their single-mode counterparts. Single-mode fiber is typically used for longer distance transmissions between buildings.
Additionally, single-mode fiber cables have extremely fast transmission speeds and are immune to distortion, again making them ideal for longer distance runs.
Typical applications include facilities with large campuses, such as colleges and universities, hospital systems, CATV and more.
On the other hand, multi-mode fiber is fiber optic cable that has a core diameter of 50 or 62.5 µm. It is typically used in data centers, where shorter cable lengths are required, and other areas that require high bandwidth and uptime connectivity. On longer runs, they can experience signal distortion and loss of data transmission.
Multi-mode fiber optic cables are commonly used in medical applications, aerospace and LAN networks.
Cable run distance should be your deciding factor when selecting a single- or multi-mode fiber optic cable, with cost being the number two concern. If you’re running more than 2 miles of cable, single-mode fiber should be used.
The post Should I use single- or multi-mode fiber optic cable? appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
