SICK Launches CLV500 Mini Line of Bar Code Scanners
By Dave Miyares | July 27, 2010
Minneapolis, MN – SICK announces the launch of its miniature line of bar code scanners. Barely larger than a USB plug, they can easily be installed where space is extremely limited. The CLV500 Series is also easy to configure via its online tool and configuration bar codes. These mini bar code scanners boast excellent decoding performance, with a large depth-of-field that allows for flexibility in code size and target placement.
SICK-CLV500-Bar-Code-Scanners
This ultra-compact series is ideal for applications in the OEM and machine builder marketplace, such as packaging systems, circuit board processing, robotic inspection, etc. Due to its high scanning frequency of 1,000 Hz, the CLV505 is suitable for conveyor speeds of up to 5 m/s, depending on the application. One of the smallest 1D barcode scanners available – it fits in extremely small spaces. This series also offers fast and easy commissioning using an online tool – no new software necessary.
SICK
www.sickusa.com
Filed Under: Factory automation, AUTOMATION, TEST & MEASUREMENT, ELECTRONICS • ELECTRICAL
