SICK Launches Compact, Industrial-grade TiM310 Laser Scanner
By Editor | April 3, 2013
SICK announced the launch of the TiM310 field detection laser scanner for anti-collision and presence detection. The TiM310 is a low-cost, industrial-grade laser scanner that is enclosed in a compact aluminum housing with an IP 65 enclosure rating.
The TiM310 is approximately the size of a baseball and weighs about a third of a pound. The TiM310 features a 270° scanning range that is suitable for simple, discrete I/O and field detection applications in the robotics, logistics and building automation industries. Its small size, 3W power consumption and large detection range make it particularly suitable for small vehicles.
SICK-TiM310-Laser-Scanner
With 16 preconfigured fields, the TiM310 can be configured in less than five minutes, which reduces installation time and costs. A “Touch and Teach” button further simplifies setup since no manual computer settings are required. For complex fieldset shapes or quick in-field replacements, the easy-to-use SOPAS configuration tool can be used.
SICK
www.sickusa.com
Filed Under: I/O modules, Lasers
Tagged With: SICK
Beckhoff I/O terminal supports high-voltage measurement for renewable energy and EV technologies
Opto 22 releases groov RIO EMU distributed energy monitoring unit
Opto 22 releases new groov EPIC I/O modules for large-scale power monitoring, signal integration
lutze
Overload current-control module features super-thin form factor
