Side-Mount Level Switches from Gems
By Design World Staff | November 18, 2011
Gems® Sensors & Controls™ introduces several new versions to their LS-7 Series of robust point level switches. These compact, side mount level switches are made from Gems Versaplast™ engineered plastic for high temperature applications up to 300°F (148.9°C).
The Gems Versaplast™ engineered plastic used on these new level switches is an extremely versatile material compatible with a wide range of challenging fluids such as oils and solvents. Versaplast™ enables the new LS-7 Series sensors to provide an affordable solution for handling high temperature applications and corrosive fluids. The durable Versaplast™ LS-7 level switches are CE, UL and CUL approved, are ideal for use within methylene chloride and anti-freeze tanks, and are well suited for low coolant, low hydraulic monitoring within off-highway vehicle and transportation applications.
GEMS-LS-7-Series-point-level-switches
These new Versaplast™ LS-7 Series versions expand the broad range of small, side mounted level switches from Gems Sensors available for a wide variety of fluids or applications. Additional specifications include pressure capability to 100 psi (6.8 bar), and a float arc of just 1.25 inches – beneficial in confined spaces. Options include internal and externally installed versions, and metric or U.S. threads.
Gems Sensors & Controls
www.GemsSensors.com
Filed Under: SENSORS, Switches, TEST & MEASUREMENT
