Silicone Jacketed Ribbon Cables from Cicoil
By Design World Staff | May 15, 2009
Valencia, CA — Cicoil announces the availability of high performance ribbon cable for electronics applications requiring better flexibility, and broader temperature and other environmental capabilities than those offered by common PVC jacketed ribbon cables. Where common ribbon cables operate in temperatures of -20°F to +80°F, Cicoil’s silicone jacketed ribbon cables perform at -65°F to 260°F. In addition, Cicoil ribbon cable is submersible, and resists acids, alcohol, oil, ozone, steam and radiation; outgassing specifications meet NASA rating for space applications. Where common ribbon cable uses 32-36 AWG base strands in its wire, Cicoil ribbon cable uses 42 AWG base strands to provide extremely supple, ultra-flexibility, with a minimum bend radius of just 0.4 inch.
Ribbon cable is designed to work directly with standard Insulation Displacement Connectors (IDC). For this reason, it is often called IDC cable, and it is used frequently where simple flat cable signal connections are needed. The wire spacing and dimensions are standardized, with the wire 'pitch' (wire spacing) set at .050″ for the English version, or 1mm for the metric version.
Cicoil's ribbon cables are constructed using Ultra High Flex 28 AWG, tinned copper wire, and feature the exclusive Cicoil silicone extrusion process for a strong, flexible, clear cable. All Cicoil ribbon cables meet the standard ribbon cable dimensions, and are completely compatible with any IDC connector. Cicoil's ribbon cables provide many unique advantages:
• Flexibility – Ultra Flex, tinned copper wire conductors, and flexible silicone make Cicoil's ribbon cables highly flexible, with a bend radius as small as 1/4″ in flexing applications. Also the cables can be 'folded over' for static applications.
• Long Life – Rated for over 10 million cycles in flexing applications
• Extreme Environments – Silicone rubber cables operate from -65°C to 260°C, including exposure to water, steam, salt, and most chemicals. The cables are ideal for clean room use, and they can also be used in vacuum environments.
• Fire Resistant – Cables are fire resistant, as they meet the UL-94 vertical flame standard, as well as other fire standards
Cicoil
www.cicoil.com
Filed Under: Cables + cable management, Electronics • electrical
molex-premo-flex
