Simple Change of Pitch and Travel Direction
By Design World Staff | April 23, 2010
The Amacoil-Uhing Kinemax linear drive has easy pitch adjustment and automatic reversal without clutches, cams or gears. A dial controls the ten-toone pitch adjustment range. Setting #10 on the dial is maximum pitch. Dialing down reduces pitch.
Amacoil-Uhing-Kinemax-linear-drive
The unit also reverses direction automatically without reversing the drive motor. A mechanical reversal device changes drive nut travel direction with no interruptions in operation and without adjusting any controls. The unit has 7 lb of axial thrust and is suitable for light duty linear motion applications with low drive torque requirements. Stroke lengths of 1/2 to about 24 in. are possible.
Amacoil
www.amacoil.com
Filed Under: LINEAR MOTION, Motion control • motor controls
