Simpler Temperature Measurement
By Design World Staff | February 10, 2010
With the EL3201-0020 temperature measurement EtherCAT® I/O terminal, measuring error is reduced to ±0.1 K of the temperature measuring range.
Beckhoff-el3201
The terminal enables direct connection of a resistance sensor (PT100) using 4-wire technology. The characteristic curves of the sensors are implemented over their complete measuring range and are made available to the higher-level control system in a suitably linear form.
Beckhoff Automation
www.beckhoff.com/EL3201
Filed Under: I/O modules, Networks • connectivity • fieldbuses, Test + measurement • test equipment
mti
MTI
moog
