The DMC-30012 Series is Galil’s latest generation single-axis motion controller. It uses a 32-bit RISC processor to provide higher speed than older models. The DMC-30012 features an internal 800-Watt brushless sine drive which minimizes space, cost and wiring .The motion controller operates stand-alone or can be networked to a PC via Ethernet. Features include:
- Single-axis motion controller with on-board 800 W brushless sinusoidal servo amplifier; 10 A cont.,15 A peak at 20-80 VDC rated
- Two daisy-chainable Ethernet 100 Base-T ports. One 115kbaud RS232 port
- Ethernet supports multiple masters and slaves. TCP/IP, UDP and Modbus TCP master protocol for communication with I/O devices
- Encoder feedback up to 15 MHz. Quadrature standard; SSI and BiSS encoder option. Main and auxiliary encoder inputs
- Non-volatile memory for programs, variables and arrays
- Concurrent execution of four programs
- Optically isolated forward and reverse limit inputs and homing input 8 uncommitted, isolated inputs and 4 isolated outputs
- High speed position latch and output compare
- 2 uncommitted analog inputs and 1 uncommitted analog output
Galil
servo2go.com
Filed Under: Factory automation, Motion control • motor controls
