EXAIR’s siphon fed spray nozzles atomize fluids in a range of spray patterns for a wide variety of uses. Siphon fed atomizing nozzles require no liquid pressure and can be used with gravity fed liquids or lift liquids from a siphon height as much as 36 inches (91cm). They combine liquid and compressed air to create a thin coating of liquid that can be easily adjusted to meet the needs of your application.
With EXAIR’s siphon fed atomizing nozzles, you can coat, cool, treat and paint a variety of products using compressed air and liquids with a viscosity of up to 200 centipoise. Used with water, atomizing nozzles are an efficient way to evenly cool hot items in your automated process.
The stainless steel construction of these atomizing nozzles adds to their durability and corrosion resistance. EXAIR atomizing nozzles are available in a variety of flow patterns and rates to meet your needs. Internal mix and external mix atomizing nozzles are also available. All models are adjustable and come with our 5-year Built to Last Warranty.
EXAIR Corporation
www.exair.com
Filed Under: Pneumatic Tips, Pneumatic equipment + components
