SKF earns Manufacturer Excellence Award
By Mike Santora | February 16, 2021
SKF-Cooper-split-spherical-roller-bearingThe SKF Cooper sealed split spherical roller bearing, the only sealed split spherical roller bearing currently on the market, has earned a 2020 Manufacturer Excellence Award for Innovation in Product Design from the Bearing Specialists Association (BSA). This the third BSA Manufacturer Excellence Award for SKF. The company was honored in 2019 for the SKF Pulse vibration sensor and mobile app, and in 2017 for the SKF Multilog On-Line system.
Both the open and sealed versions of SKF Cooper split spherical roller bearings are designed for easy replacement with little disturbance to the shaft alignment or driveline and eliminate the need to remove attached equipment. This innovative solution reduces mean time to repair (MTTR) and equipment downtime by up to 70 percent, which dramatically reduces customers’ cost of repair. The sealed version has a machined seal within the bearing for superior contamination protection. This reduces environmental impact by lowering grease consumption and is ideally suited for harsh application environments – such as conveyor pulleys, stacker re-claimers, and other critical equipment.
“We are honored to be recognized by our industry peers for the innovation and advantages SKF Cooper split spherical roller bearings offer customers. We’re proud of the safer working environment this product creates,” said Will Hidell, Vice President of Sales, Aftermarket, and Channel Management for SKF USA.
“More than 40% of accidents in the mining and cement industry occur while workers are examining or maintaining conveyors. By eliminating the need to dismount drive couplings or cantilevered drives during maintenance and replacement, our bearings help create even safer conditions for our customers’ personnel.”
The Bearing Manufacturer Excellence of Innovation in Product Design Award recognizes companies for innovation and excellence in product design or technology. BSA distributor members reviewed and ranked manufacturer’s innovation submissions and three submissions were recognized for their outstanding service to the end-use customer.
SKF
www.skf.com/us
Filed Under: Bearing Tips
Tagged With: SKF
