SKF insert bearings (Y-bearings)
By Mike Santora | January 31, 2023
skf-y-bearing-CAD-product-imageInsert bearings (SKF Y-bearings) are based on sealed deep groove ball bearings in the 62 and 63 series, but have a convex outer ring and in most cases an extended inner ring with a specific locking device, enabling quick and easy mounting onto the shaft.
Product details
Designs and variants
Lubrication
Bearing data
Loads
Temperature limits
Permissible speed
Design considerations
Mounting and dismounting
Designation system
Features and benefits
Quick and easy to mount
The different locking methods enable quick and easy mounting of insert bearings onto the shaft.
Accommodate initial misalignment
The spherically shaped outside surface enables initial misalignment by tilting in the housing (fig. 1).
Long service life
The different sealing solutions available provide a long service life for a wide variety of applications with high contamination levels.
Reduced noise and vibration levels
Where high requirements on noise and vibration levels are important, SKF can provide the appropriate shaft locking method.
SKF
www.skf.com
Filed Under: Bearing Tips
Tagged With: SKF
