SKF has a range of new products available. Here are just a few of the new items from the global bearing and solutions company.
Multipoint Automatic Lubricator- TLMP series
Centralized and ready-to-use system to automatically lubricate multiple bearing lubrication points in rotating equipment.
Packaged as complete kit for easy installation.
One liter reservoir capacity
Stirring paddel to prevent grease speration
Cycle control sensor to govern delivery of lubricant
Alarms to signal love levels and malfunctions
TKSA 71 Shaft Alignment tool- High end aligment tool for harch environments that comes in one self-contained package.
Compact and durable for precise aligmenent measurements of rotating shafts.
Completely sealed
3-position measurments can be akent from up to 32-ft. away.
Free, easy-to-use software apps: 3D live view, export sharing options, comprehensive automatic reports.
SKF remanufacturing services for gearboxes- On-site inspection and initial diagnosis before gearbox is sent to one of SKF’s facilites. The service brings a complete portfolio of services and capabilities implemented at dedicated centers in SKF Solution Factory network. Skilled specialists apply advanced engineering and components.
Systems approach to refurbish and/or upgrade obsolete or damaged gearboxes and quickly return them to service.
Diagnoses root causes of failure and prescribes techical remides for fixes.
All gearbox types and brands are candidates.
SKF
www.skf.com
Filed Under: Bearing Tips
