SL Power Electronics announces its CINT1150 family, the latest offering in the high density single output open-frame AC/DC power supply line. Approved to EN/IEC/UL60950-1, 2nd edition, the CINT1150 family is ideal for lighting, industrial printers, gaming equipment, and many other applications where power density and cost are critical.
Measuring only 2″ X 4″ and less than 1U (1.3″) high, the CINT1150 provides 150W of output power under 200 linear feet per minute (LFM) airflow with 91% efficiency at 240Vac and 100W under convection. It surpasses Class B Conducted EMI and Class A with 6dB margin for radiated EMI. Compliant to EN61000-4-2, 3, 4, 5, 6, 8, and 11 EMC specifications, the CINT1150 series power supplies will ensure system-level compliance for those applications requiring compliance to these world-wide specifications. The CINT1150 operates at universal input range of 90 to 264Vac and wide temperature range -10°C to +70°C, delivering full rated output power up to +50°C. The CINT1150 models come with standard outputs of 12Vdc, 24Vdc, 48Vdc and 56Vdc. In addition, they feature Power Fail and DC OK signals.
www.slpower.com
SL Industries, Inc.
www.slindustries.com
Filed Under: Hose • wraps + sleeves, ELECTRONICS • ELECTRICAL, Power Electronic Tips
