Slide switches available in compact package sizes down to 10 x 2.5 x 5.9 mm
By Editor Design World | April 29, 2021
CUI Devices’ Switches Group announced the addition of slide switches to its product portfolio. Available in compact package sizes as small as 10 x 2.5 x 5.9 mm, the MSS series is a family of mini slide switches featuring 2.54 mm pitches, SPDT circuits, and on-on switch functions. Thanks to their compact footprints, these mini slide switches are ideal for a variety of space-constrained consumer electronics, industrial control, and test equipment applications.
These slide switches offer surface mount or through-hole mounting styles, raised or flat actuator levels, gull wing or PC pin terminations, and vertical or horizontal orientations. The MSS series further carries rated voltages of 12 or 24 Vdc, rated currents of 300 or 500 mA, and operating temperature ranges from -40 up to 85°C. All models hold the UL94V-0 flammability rating and are RoHS compliant.
CUI Devices’ slide switches are available immediately with prices starting at $0.57 per unit at 500 pieces through distribution. Please contact CUI Devices for OEM pricing.
Filed Under: Sensor Tips
Tagged With: cuidevices
What sensors are used in AR/VR systems?
What’s an acoustic leak detector?
Touchless angle sensorssport IO-Link output interface
How can sensors help cleanup waterways?
