  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
SLN torque limiter with clamping hub for indirect drives
By Mike Santora | July 13, 2020
R+W-SLN-torque-limiter
Design
*with clamp collar and screw per ISO 4762
components of compact and rigid design with backlash-free interface
*Temperature range: -30° C to +120°C (-22° F to +248° F)
*Service life: These couplings are maintenance-free and stable over their entire service life if technical limits are not exceeded
*Tolerance: Overall clearance between shaft and hub 0.01-0.05 mm.
Function system:
W = single position engagement (standard)
D = multi-position engagement every 60° (30, 45, 90° optional)
Design/Features:
extremely lightweight construction
up to 60 % weight reduction in comparison to the standard series
torque rating increased by 50 %
good dynamic characteristics
spring-tensioned ball-detent principle with absolutely zero backlash
corrosion resistant
very simple torque setting
Properties of Torque Limiter model SLN:
integral bearing for timing belt pulley or sprocket
compact, simple construction
torque setting is continuously variable
frictional clamp connection
simple to install
R+W
www.rw-america.com
MOTION DESIGN GUIDES
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High Strength, NASA Low Outgassing Approved Epoxy
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
