SM Series Magmeter from ifm efector
By Dave Miyares | July 3, 2009
EXTON, PA — ifm’s SM Series Magmeter is a magnetic inductive flow meter that is designed to reliably detect the flow rate of conductive media up to 26 gallons per minute. The SM Magmeter’s stainless steel, mechanically-robust design is mounted in-line providing a compact, low-profile installation for process control.
The sensor display includes a 4-digit numeric display with eight integrated LEDs that together indicate the flow rate (gal/min or l/min), total volume (gallons or liters), and temperature (°F or °C) of all conductive media. Simple pushbutton programming quickly establishes application parameters and the flow meter can be setup to provide a switching output, analog output and pulsed output.
The sensor offers high accuracy with a response time of less than 0.15 seconds and a repeatability of ±0.2%. Electrical connection is made through an M12 connector.
The principle of operation is based upon Faraday's Law of electromagnetic induction that detects the flow velocity of an electronically conducting fluid through a defined pipe diameter. Faraday’s Law states that the voltage induced across any conductor as it moves at right angles through a magnetic field is proportional to the velocity of that conductor.
ifm efector, inc
www.ifmefector.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
