SMA connectors deliver 9 GHz frequency in 165 °C environments
By Redding Traiger | May 2, 2025
Amphenol RF is pleased to introduce new high-performance SMA connectors suited for use with versatile high-frequency 0.81 mm cable or 1.32 mm Double Shielded cable. These SMA plugs feature a threaded coupling mechanism ensuring a secure connection even in rigorous applications. The connectors are tested for up to 500 mating cycles, guaranteeing durability and reliability. The 165°C maximum temperature range ensures unrelenting performance in harsh conditions where temperature resistance is crucial. Supporting up to 9 GHz, the maximum frequency for many micro-coaxial cable types, these connectors support the frequencies required for Wi-Fi 7 applications. Preconfigured cable lengths and custom cable assemblies are available upon request.
With a durable gold-plated brass body and contact, SMA connectors are engineered to endure corrosion resistance and provide longevity for any usage. A stainless steel retaining ring holds the PTFE insulator and contact in place, while a silicone gasket ensures a sealed and secure connection. When assembling the connector, the center contact must be soldered and the ferrule crimped with a 0.105” hex crimp. Stripping dimensions for each connector are provided on the product drawings. With high-frequency capabilities, reliability, and quality materials, SMA connectors are ideal for demanding applications such as antennas, telecommunications, and military & aerospace.
These SMA plugs join a wide portfolio of SMA connectors designed as off-the-shelf solutions for all RF design projects.
Filed Under: Aerospace + defense, Connector Tips
Tagged With: amphenolrf
