Harwin continues to extend the scope of its high-reliability (hi-rel) connector portfolio through the introduction of mixed-layout versions of its popular Gecko-SL series. By complementing the data contacts with 2 or 4 power contacts (in power/data configurations of either 1+8+1 or 2+8+2), the Gecko-MT products enable significant space and weight reductions in electronic hardware. This means that they address modern system designs where major constraints can be placed on these parameters. The respective power and data current ratings are 10 and 2.8 A max per contact.
The initial release comprises female and male cable connectors, plus female vertical and male right-angle PCB connector options. These components are fitted with sturdy, stainless steel screw-lok fixings (in both conventional and reversed formats), to ensure ongoing interconnect integrity in even the most challenging of application environments. They have 20 G vibration and 100 G shock resilience and their operational temperature range spans from –65° to 150°C. Low outgassing properties are also exhibited.
By encompassing both data and power in a single compact and lightweight solution, Gecko-MT connectors are highly optimized for avionics, defense, space, and motorsport. Among the key target applications are robotics, unmanned aerial vehicles (UAVs), battery management and satellites. They are available from stock and through Harwin’s distribution network. In addition, cable assemblies can be requested for manufacture by Harwin’s in-house operations.
“By specifying Gecko-MT, engineers will be able to streamline their designs, improve size and weight profiles and reduce bill-of-materials costs by using a smaller and lower-cost component than comparable Micro-D connectors,” states John Brunt, Product Manager for High-Reliability at Harwin. “By combining together power and signal in one robust mating pair, savings can be made in both weight and space, without any compromise in performance or longevity.”
Harwin
www.harwin.com
Filed Under: Uncategorized
