Small external mix spray nozzles coat, cool, treat and paint
By Mike Santora | May 18, 2018
18EFmix_PR3mbexair-atomizing-nozzle-spray-imageEXAIR’s new 1/8 NPT small external mix spray nozzles atomize fluids up to 25 gallons per hour. External mix nozzles are great where a high volume of liquid is needed. They can be used on liquids with a viscosity up to 800 centipoise. Small external mix nozzles are available in a narrow-angle flat fan pattern and are the best choice when a thicker liquid needs heavy application over a narrow band. They combine liquid and compressed air to create a coating of liquid that can be easily adjusted to meet the needs of your application.
With EXAIR’s 1/8 NPT small external mix atomizing nozzles, you can coat, cool, treat and paint a variety of products. Used with water or coolant, atomizing nozzles are an efficient way to evenly cool hot items in your automated process. Since they are external mix, airflow and liquid flow can be controlled independently which provides the most precise liquid flow.
The stainless steel construction of these atomizing nozzles adds to their durability and corrosion resistance. EXAIR atomizing nozzles are also available in 1/4 and 1/2 NPT. A variety of flow patterns and liquid rates are available to meet your needs. Internal mix and siphon fed atomizing nozzles are available too, as well as patented no-drip versions of every atomizing nozzle. All models are adjustable, CE compliant and come with our 5-year, Built to Last Warranty. 1/8 NPT External Mix price is $181. Prices for all EXAIR atomizing nozzles start at $155.
Exair
www.exair.com/58/1_8extmix.htm
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES
Tagged With: exair
PTDA Foundation now accepting nominations for 2022 leadership awards
HERMES AWARD – Jury nominates three solutions
FAULHABER-integriert-PDT_220401
FAULHABER integrates subsidiary PDT
pneuw455x255hr_LB2
EXAIR Webinar Series: Break the cycle of replacing electric shop vacuums
