Small, Powerful PCB Relay Designed For Electric Vehicle Charging Stations
By TE Connectivity | October 31, 2017
TE Connectivity (TE) has introduced the Potter & Brumfield Power PCB relay T9V series designed for electrical vehicle charging stations, charging cables and for photovoltaic inverter applications. With 40A / 250 VAC ratings in a small form factor, the T9V series relay enables PCB space savings and ultimately smaller applications. The extended contact gap (>1.8mm) provides better isolation and full disconnection of the grid, enabling applications at higher altitudes.
TE’s T9V series relay can be driven with reduced coil power down to 350 mW, meaning that less energy is needed during the duty cycle and lower self-heating. This enables cost savings by lower energy consumption and lower heat dissipation.
TE’s T9V series relay is in accordance with IEC 60335-1 and has a common pin layout which makes this a relay that can be fitted for many existing applications and designs. It is a global relay solution with UL, CQC, TUV and VDE certifications.
For more information on Potter & Brumfield Power PCB relay T9V series, contact the Product Information Center at +1 800 522 6752 or visit
http://www.te.com/usa-en/about-te/news-center/t9v-relay-npi.html.
