    • On the Floor
Small size, big performance industrial cameras for precise error-proofing
By Marisa Martin | June 27, 2016
The new CX series industrial cameras from Baumer are specifically designed to easily handle tough quality and error-proofing challenges in the Assembly industry. The broad range of sensor models includes both GigE and USB 3.0 cameras with resolutions from VGA to 5 Megapixel.
Measuring only 29 x 29 mm, these cameras feature one of the smallest designs available on the market. They fit easily into even the narrowest installation environments yet provide a high degree of flexibility. Camera events and the integrated image memory ensure synchronized process control for long-term stability in image evaluation. The GigE models with Burst Mode enable higher frame rates than provided by the interface bandwidth which gives the user a wide application potential with all the benefits of GigE Vision. The cameras have an operational housing temperature of up to 65 °C for excellent image quality even in diverse applications.
The USB cameras utilize only a single cable for high data transmission rates and easy integration by Plug & Play functionality. GigE cameras with 12 to 24 V power supply or PoE (Power over Ethernet) perfectly comply with conventional automation requirements.
Baumer
www.baumer.com
The post Small size, big performance industrial cameras for precise error-proofing appeared first on Robotic Tips.
Filed Under: Cables + cable management, Vision • machine vision • cameras + lenses • frame grabbers • optical filters • scanners
Tagged With: baumer
    • On the Floor
