The ZG05HV Series features a specialized housing that delivers sufficient creepage and spatial distance between contacts, enabling a high-rated voltage (1,000V) and withstanding voltage (3,000V) in a compact size. With a pitch of 3.3 mm, the size 0.5mm tab-sized connector combines space-savings and high performance without compromising reliability.
A 3-point contact design (one spring and two embossed contact points) combined with a double-layered spring increases the contact force and prevents vibration from outside, enhancing reliability in high-vibration conditions. In addition, the depth of the contacts within the housing eliminates the risk of electric shock during assembly.
A mating key prevents mis-mating when using multiple connectors.
The ZG05HV Series is currently available in a 6-position version, with a 10-position connector under development.
Filed Under: Connector Tips
