    • Subscribe!
SmartWire is compatible with Ethernet/IP
By Editor Design World | June 19, 2012
The SmartWire-DT panel wiring solution uses an eight-conductor, flat cable located in the control cabinet to connect motor starters, pushbutton actuators, and indicator lights. The start of the system is a SmartWire-DT gateway, which establishes the connection to standard programmable logic controller (PLC) fieldbuses, now including Ethernet/IP and Modbus TCP, as well as PROFIBUS-DP and CANopen. This added flexibility allows the SmartWire-DT system to more easily integrate with original equipment manufacturer’s (OEMs) preferred industrial network.
Eaton Corporation
www.eaton.com
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
Tagged With: eaton
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
    • Subscribe!
