Amphenol RF has expanded its SMP product line — a high- frequency, subminiature interconnect solution — to include several new thread-in mount jacks, a straight cable plug and a bullet adapter. This connector series is designed for blind mate applications with a variety of board spacing and package size requirements.
The three additional SMP straight jacks feature a thread-in bulkhead design with post contacts and push-on coupling mechanism. These 50 ohm connectors are constructed with gold plated brass and are available in limited detent, full detent and smooth bore interfaces.
A new straight solder plug is optimized for 0.047 in. semi-rigid cable and is designed with an anti-rock ring for vibration resistance. This connector features the familiar push-on coupling style and is constructed with gold plated beryllium copper.
The SMP plug to plug bullet adapter is designed to compensate of both radial and axial misalignment and is now available in 17.16 mm length.
The SMP series operates at DC to 26.5 GHz making this product family ideal for applications that require a high data rate transmission, such as broadband, instrumentation and telecommunications applications.
Amphenol RF
www.amphenolrf.com
Filed Under: Uncategorized
