SMVector Frequency Inverter from Lenze-AC Tech
By Design World Staff | October 9, 2008
UXBRDIGE, MA ‚– Lenze-AC Tech announces the release of the SMVector Frequency Inverter with a highly visible Internal Disconnect switch. Available on NEMA 4X (IP65) enclosed drives; the switch removes power to facilitate service and maintenance. According to Lenze-AC Tech officials, use of the Internal Disconnect Switch in decentralized ‚“point of use‚” operations including conveyors, fans, pumps, material handling, stackers and sorters will result in reduced downtime, with operations getting back on-line faster.
Mentioning how local electrical codes in many parts of North America require a means of power disconnection at the motor, Lenze-AC Tech VFD Product Manager Steven Dextraze states, ‚“The minimal footprint of the SMVector with Internal Disconnect helps electricians, installers and OEMs meet those codes with one piece of equipment.‚” According to Dextrase, besides saving valuable real estate on the production line, the Internal Disconnect reduces equipment cost by eliminating the need for a separate external disconnect switch mounted in its own enclosure, and of additional wiring between the external disconnect and the SMVector drive.
www.actech.com
Filed Under: Drives (ac) + VFDs + starters, Motion control • motor controls
