Binder USA LP has added to its 720 series of miniature circular connectors with a new snap-in IP67 twin distributor. The new twin distributor — a single male connector into two female connectors — provides a welcome new option for designers and installers who need a miniature circular connector for today’s machine building and automation applications.
The new twin distributor features 3 and 5 gold-plated contacts rated up to 7 A at 250 V (5 A at 125 V). The twin distributor is also a compact robust splitter, the ideal solution for splitting off a connection with two protected paths.
The IP67 protection rating makes the binder Twin Distributor ideal for use in applications where a simple waterproof connection is needed. Medical grade versions are also available.
Product highlights include:
- Twin distributor: male connector into two female connectors
- Wiring: 1:1
- Contacts: 3 and 5
- Degree of protection: IP67
- Rated voltage: 250 V – 125 V
- Rated current: 7 A – 5A (per conductor)
- Contact plating: Au (gold)
- Colors: Black (standard), red, blue, or green
Binder USA
www.binder-usa.com
Filed Under: Connectors (electrical) • crimp technologies
