Click here to view the welding helmet’s full specifications.
Snap-on‘s latest product feature is the Phantom Auto-Darkening Welding Helmet. Patented, quick-adjust comfort fit headgear offers simple, push-button adjustments. Plus, a new compact shell allows for better performance when used in closed or tight work spaces.
The welding helmet also has flexible lighting options. There’s a multi-function light. In fact, it’s a 360-degree pivot LED with light-balance technology.
Additionally, a flip-out light is fully integrated into contour of the helmet when not in use. When activated, simply rotate the light to the desired angle based on the helmet’s position to clearly view the work area, whether the helmet is raised or lowered. It offers a 180-degree view with a fixed shade.
Two side lenses provide an excellent peripheral field of vision compared to standard “bread box-style” helmets.
Additional feature:
• Extra-large, four-sensor ADF
• Solar chargeable with battery backup
• iHD viewing with True Color technology
• Full wrap-around slag shield
• An on-trend design that stands out from older style models
Filed Under: Welding • soldering
