The CT9010 18V 3/8″ Drive Brushless Cordless Impact Wrench Kit comes equipped with a two-year warranty for the tool, the charger, and the battery.
Snap-on Industries‘ new CT9010 18V 3/8″ Drive Brushless Cordless Impact Wrench Kit is designed for the heaviest applications that demand consistent high performance.
The CT9010 is lightweight yet still provides maximum power on the job and boasts a monstrous 240 ft-lb of working torque output — and more than 325 ft-lb of bolt breakaway torque.
Stubborn fasteners are easily broken away with this durable, professional grade impact wrench. The digital microprocessor-controlled switch maximizes performance with three variable forward and reverse settings that help the tool adapt to various applications.
A built-in brake quickly stops the anvil to prevent throwing fasteners while the brushless motor provides a smooth start-up.
The CT9010 weighs only 4.9 lb. with the battery, and its bright 100 lumen LED headlight illuminates the work area making it the perfect choice for challenging, dimly lit tasks. The CT9010 kit includes two 5Ah batteries and charger with a built-in USB port.
Features
• Up to 240 ft-lb of torque in a compact housing for tighter clearances
• Digital microprocessor-controlled switch that maximizes performance, run time, and durability
• Three torque settings in forward and three in reverse to adapt to various applications
• Built-in brake prevents tool from throwing fasteners and sockets
• A 100-lm LED illuminates work area
• Lightweight — 4.9 lbs, with battery
• Kit includes tool, (2) batteries, and a charger
• A two-year warranty for the tool, charger, and battery
