Software Increases Inspection Accuracy
By Design World Staff | June 11, 2008
Geomagic Qualify 10 is a computer-aided inspection software for multi-sensor metrology systems. The software streamlines workflow, improves alignment accuracy, and provides full inspection coverage, letting you take advantage of the combined strengths of 3D scanners and hard probes. A single interface lets you completely inspect every type of shape and feature that characterizes an object, saving time and increasing inspection accuracy.
New capabilities in Geomagic Qualify 10 let you quickly detect and inspect geometrical features such as points, holes, slots, cones, cylinders, planes and spheres. The software automates feature creation and tasks such as calculating size, analyzing fit, comparing 2D and 3D features, and measuring point-to-point and feature-to-feature distances and angles. A new streamlined feature framework lets you efficiently analyze, measure and report dimensional characteristics and fitting statistics of geometrical features.
The new hard probing and 3D feature capabilities are fully integrated with functions such as alignment, GD&T, and 2D and 3D dimensioning that are popular with users of 3D scanning systems that generate dense point clouds.
The software supports 32- and 64-bit versions of Windows XP and Windows Vista. The 64-bit edition lets you take advantage of the expanded memory capacity of 64-bit computer systems to process huge datasets generated by the newest generation of non-contact 3D scanners.
Geomagic
www.geomagic.com
:: Design World ::
Filed Under: ENGINEERING SOFTWARE, TEST & MEASUREMENT
